puddinhead025
If a building permit is taken out in 2004 and the foundation and footing are install in 2004 and the building is underconstruction in 2004.
Do I have to install a Eufer ground because I came on the job in 2005 and took out the electrical permit 2005 that is when the Eufer ground became required in MA.
The electrical inspector is making us chip out the footing , expose the rebar and make the connection, that just seems to be a bit excessive considering the footings etc were installed before the requirement.
I personnally don't believe there is a great safty issue if this Eufer ground is not in place...
thanks
thanks
