Brian Martin
- Pennsylvania USA
- Generators - Standby Cogen Trigen
I'm helping a friend in Europe understand if he can safely use a basic USA-type portable generator to power his European 240V 2-wire appliances which can accept 60HZ.
I think he needs to lift the usual USA generator center-tap neutral from generator chassis. And maybe bond the one 240V line which serves as Neutral in Europe. (if the USA generator has no features using 120V line-to-neutral power.
But I wonder:
But I wonder:
- Do most larger European 240V appliances have the one leg bonded to the appliance chassis.
- Or, are both legs isolated/insulated from the chassis? (which would reduce the safety concern, I think) (If neither leg is bonded, that means the chassis becomes connected only by means of the earthing tab of a Type F “Schuko” plug when connected via a 3-wire cord...and chassis is total unconnected if using a 2-wire cord)
