- Illinois
- retired electrician
Ok, I did not understand that you had a GFCI breaker, but should have since you said it is cord connected and the receptacle requires GFCI protection.The Emporia EV charger has built in GFCI. It does a self-test every so often. Emporia tech support confirmed that when the EV charger performs a self-test, it will trip the GFCI breaker since the breaker tolerance is only 5mA.
