Hello,
I'm looking to install an EV Charger.
Am I interpreting the code correct that if it's under 60 amps it does not need it's own disconnect?
If it is over 60 amps and the panel is within sight, can the breaker count as the disco? It would definitely be readily accessible. I could add a breaker lock if that was necessary.
Thanks
Thanks
