jbgoosehunter
At my work there has been a 208 V 3 phase 225 amp panel installed in a commercial walk in freezer. Over the years there has been some water damage from the freezer being defrosted however the panel still works. It just seems like an odd place for an electrical panel. The panel is just a standard QO style square d panel. Its not weather proof and has eccentric ko's in the top of it. The tempreture is kept between 0 and 28 degrees F. in the freezer but ocasionally they defrost it. The freezer typically has frost on the walls. We are in the process of remodeling the freezer and I'd like to re-locate the panel outside of the freezer. I just need some code back-up to convince the boss that it is the thing to do. I cant find any specific info in the code related to a panel in a freezer. Ive only found stuff about the panel needing to be weather proof rated for a wet location. Has anyone ever seen this before and what are your thoughts? Please respond to [Moderator's note: email address removed. Use private message to initiate contact.]
