cvirgil467
- NewYork
Hi there.
We are replacing out the existing service conductors that originate from a property line box and terminate in a CT cabinet. The incoming service conductors within the CT cabinet doesn't seem to grounded to a grounding electrode. Nor are they within the existing service switch enclosure. The service conduits into the CT cabinet from underground are bonded together to the CT enclosure.
I can use the existing main cold water pipe and run a grounding electrode conductor to be confident that the service is grounded. My question is where would I terminate the grounding electrode conductor from the main cold water pipe - to the CT enclosure or to the service switch enclosure?
Thanks.
Thanks.
