SolarBill
- Corona, CA
1st post, so will try to make sure I'm to the point and appropriate. I have already searched the PV Threads for this topic, but haven't found this specific issue.
We have a customer with an older Murray/Siemens 12/24 with what we believe to be 100A bus (based on Service Disconnect OCPD 100A), the inspector has given us the correction "Existing panel is not labeled – plans call for 100A panel which cannot be verified – Solar breaker usage in this panel cannot be verified". Is there any code or guidance for inspectors to determine bus rating? We always were under the assumption (yes I know what I'm doing when I assume), that if there is no Manufacturer's Label/Sticker then we assume the bus is the same as the Service Disconnect. We are trying to connect a 2-pole 20A backfeed breaker, but he won't give me the final without upgrading the main and we don't want to put the customer through another $1500-2500 if there is some way to get it final'ed without.
Any ideas or guidance?
