Exposed Copper on Power Wires
1/16th-1/8th" copper exposed is what I use for breakers, and wrapping screw terminals: I dont want insulation under the connection or it can cause a loose connection. Wagos/push-in connectors, backstabs, wirenuts, butt splices, and fork/ring terminals, I dont want any exposed copper.
On neutral and ground bars, and things like disconnects I prefer to see a tiny (1/8th") bit of wire coming out the other side so that I know the connection is solid and the screw isnt tightened down on just the tip of the wire. On blind connections like the inside of a disconnect ground bar, I loosen one screw only with the other tightened down so that the 1st ground wire doesnt wind up under 2 screws.
I dont think there is a 'one size fits all' measurement for all connections, and there is no NEC specs/rules afaik.
