I can't seem to find in the NEC how much exposed wire is allowed on a neutral conductor when it terminates at a neutral bus bar. For instance, if you see an installation where 1/8" of bare neutral wire is exposed at the connection (too much insullation was stripped), is this a problem as long as all minimum spacings to ground and hot conductors are acceptable? Does anyone have any thoughts on this? Thanks.
