Alwayslearningelec
- NJ
- Estimator
Ok while I am on a roll. If you are doing lighting/power in a few rooms that have exposed slab ceilings(existing constructions) and block walls how is the piping run to other rooms though the walls...more so for the lighting? Penetrations through the walls @ the ceiling height?? These(if that how you would run conduit to different spaces) would not be cores I assume as that only takes place through slabs? How would you penetrate a block wall? THanks
