Scenario: contractor for a city "splash pad" water feature (kids water fountain) covered work prior to inspection of exponential gound bonding system as called for in 2005 NEC, 680.26 and 680.55. The contractor, not the electrician, did the bonding. No one, other than the contractor can verify what was installed prior to concrete placement. There is 50 volts at the control panel fed from a stepdown transformer approximately 120' away. Control panel operates the timing mechanism and water spray features. The service is grounded at the stepdown transformer location (fed by a 30 amp CB). All water supply and drain piping is PVC. There are metal fittings for poles and spray features on the pad and there is a rebar grid within the concrete deck.
Need advice on how to get the contractor to assume liability for their work (no state licensed electrician performed the work) to protect the public and city. How can you verify that the expotential bonding system is 1) intact and bonded to all metal within the deck area, and 2) what resistance reading is acceptable for the expotential bonding system. I know that 25 ohms is acceptable for the grounding system, but what is proper for the expotential bonding system?
They have offered to provide test reports from a lightening protection firm specializing in grounding, but I need to know what the report should specifically say. I know this is a lot to ask for, but I believe I've come to the right place to help me in this matter. Thank you in advance.
