I'm looking to install a 20A outlet on a pedestal under a soft cover (golf cart 'shed') at a camp ground, on a permanent site. (Yes. I'll be using waterproof enclosure, with all the trimmings). As the distance is about 100' from the power source (site's ped), I'm planning on installing 10GA UF cable inside some conduit (most likely sched 80 or equiv). This is the source of my dilemma... What about the the LOAD side. As I can't directly tap into the campsite's power ped, the customer asked if we could bury an extension cord (already said no, hence the cable and conduit). The question is: if I put a 20A power inlet near that main ped, would that follow code for the customer to run a short extension cord between power inlet and main ped (ensuring 20A cord)? He wants to use that remote outlet to charge his golf cart.
I can't find anything talking about this, and am looking to see what others have done with this.
Thanks
Thanks
