Extending 15a Circuit to Shed
electrificator
New User
Detroit
Engineer
I am planning to run power to a very small shed by extending an existing 15a circuit that currently feed only a gate operator (4.5amp). I only need power at the shed for a light and a single receptacle for the occasional small power tool. The gate is fed by (3) #14 wire in PVC conduit about 100'. I plan to tap into the existing junction box at the gate and run THWN #14 wire underground (18" depth) in a 3/4" conduit about 75' to the shed. I will use a small disconnect and a GFCI at the first receptacle. My questions:
1. Will there be a problem with voltage drop if running #14 wire that far? I assume it does no good to run heavier wire unless I replace the existing run of #14 with the same.
2. Is schedule 40 PVC conduit sufficient for running a 120v, 15amp circuit 18" down in a residential yard?
With all due respect to your profession... This appears to b e a DIY job not associated with your engineer title.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the top right corner of the post.
