Code Question
Typically when adding another panel I’ve seen where a parallel service is ran and service increased to 400A split at the meter. I’ve also seen a sub panel added to an existing panel.
Have you ever seen an existing 42 breaker panel with the SER CABLE coming in at the top of the panel to a main breaker then at the bottom SER cable connected to the bottom via lugs extending to another panel? A panel extension if you will.
Assume it can handle the load, can you do this?
