construct
- Branson, Missouri
Huh... you're kidding right.
My thoughts also (voided equipment listing).
This is from an inspection report that I was asked to review yesterday. Any idea what he is talking about?
"The further the service outlet is away from the unit this could affect the overall reaction time the unit will need to retract properly."
There is an extention cord used to supply power to a GDO.
The simple answer has already been mentioned. It is a violation to use the cord. Will it cause a safety issue depends on guage and length. I rather dought a #14 even 25 feet long would have a voltage drop to worry about. Would suggest they wire in another box that is in reach. In short what they have is a NO GO by code. We all see things that violate code but work just fine.
Almost true, you left out that it is one more plug and receptacle. There is a loss but yes very little and being it is a GDO would not even be on for a minute. So yes will work but we can not ignore that it is a fixed appliance so extension cord is a no can do. If seller refuses to fix then by guess is buyer would still buy it. Many old houses are sold on an as is contract. Buyer might back off if HI produces too many items that are defects. I am bidding on a house next to me listed for $249 k, I offered the bank 40 k cash and with this economy i might just get it for that or something near it. Would be no point in picking it apart to get them to fix it. Needs about 30 k in work.I agree , I would want an outlet installed so the factory cord would reach, but in reality if that is a 15 amp circuit the GDO wont know if the current came from extending #14 nm or the# 14 sj :grin:
But the problem with the extension cord is that in 5 years the rubber covering of the cord may have dried out and cracked and fallen off exposing the conductors underneath to potential damage.
Chris
I think a quality cord will last for much longer than that and likely out live the GDO
Would it be fair to say that with a properly sized cord 10-25' 14AWG that you would not be able to tell any difference from it being plugged in with 3' of the opener?
Wouldn't this be the same as in an extra tall garage where you use a cord to reach the 12' ceiling?
And we all know that the homeowner will use a "Quality" cord.:roll:
Chris
Chris
I'm not even sure that I can say this right, he had the right answer, but the wrong reason. That's the thing that makes it seem so confusing.
The HI was alert enough to know its not normal. So give him 10 points for catching it and 0 points for reason .
Do we even want to know about the ground ?
I do see danger in being undersized a bit but i bet it worked just fine
I am inclined to agree in general. But it's still not a "good" idea and a code violation.I see no safety issue.
