msteiner said:Does anyone have contradictory experience?
Maybe I'm using a different IBC version, but I don't have an asterisk, and Appendix A is "Employee Qualifications".Mr. Bill said:Notice the astrix next to that section number you quoted in the IBC. It means refer to Appendix A for additional clarification. In Appendix A they say that emergency light is not required to the public way but only to a safe distance from the building. I think this is what you're looking for.
That presumes that whatever caused the power outage inside the building did not affect the parking-lot lighting, doesn't it?bphgravity said:In some cases, the exterior parking lot lighting and/or site lighting will serve the purpose of illuminating the exit discharge.
In our city, the police/fire department have an ordinace that requires a certain ammount of illumination to be provided at all times in parking lots of commercial facilites. This usually provides sufficient illumination at the exterior exit and exit discharge.
LarryFine said:That presumes that whatever caused the power outage inside the building did not affect the parking-lot lighting, doesn't it?
Keri_WW said:Yeah that is basically what NFPA 101 7.8.1.4 states. I would also make the argument that in the case of fluorescent, MH, etc you will also need more than one ballast in case it is not the lamp that fails, but rather the ballast.
I'd believe that as long as your single ballast will keep one tube lit, no matter what.Ragin Cajun said:NO NO NO!!!
The code says "BULB". NOT lamp, ballast, battery, etc.
bphgravity said:Yes Larry. Usually, the closest pole to the building entrance/exit will have emergency backup. These are usually the same ones that stay on all night while the rest are turned off during non-business hours.
