petedownload
I have an interesting problem at a customers house. I was called to replace some 500w halogen bulbs in two fixtures mounted on the house.
When I opened them up one bulb looked like it had been burnt and broken at the ceramic ends. The other bulb had burned out and part of the metal contact of the bulb had been melted and fused to the housing contact.
I replaced that fixture and everything was good for about 9 months or so.
Another call from the customer and I went out to find out that the same situation had occurred. They had an electrician come out and look at it.
Here is what he had to say:
Thought possibly voltage too high on one leg----nope both at around 122v
Thought maybe wrong housing (300w) used in 500w fixture----two different fixtures two different manufacturers blowing at same time?
Next idea was a power surge-----nothing else in the house was affected ...TV ,computer, appliances
His only possible fix was to swap the fixtures for regular floods.
Anybody ever run into this before?
Thanks
Thanks
