Joethemechanic
 - Hazleton Pa
 - Electro-Mechanical Technician. Industrial machinery
With the old school heaters in the magnetic motor starters I never had a problem burning up a running motor losing a phase. Current would increase on the remaining two and trip out. I can't say that since adjustable overloads have become common. Too many people jacking up the overloads so it becomes the next shift's problemThey often are not good enough to prevent motor damage if the motor is running when you lose a phase. This is especially true when the motor is operated at its service factor horsepower....a practice done by some air compressor manufacturers to permit them to use a small motor than they really should.
However some newer electronic overloads have phase loss built in. If they installed a separate phase loss relay, I can only assume that their overloads do not have that function.
