dsarvis000
- Virginia
- Commercial Electrician
I failed an inspection today bc I landed my wire for the water bonding in a lug that I installed into my main panel (bonded) and not into the actual neutral/ground bars installed on the panel.
The reason I was given was bc the water system was coming from underground and was metallic turning into an electrode and not a simple bond
My question is one is this correct, two if so where in the code does it say this, and three what’s the difference if the panel is bonded ?
