I recently finished a new build. Customer called and says that he has a room where the can lights have a faint glow when turned off.
It's only noticeable with total darkness.
This particular room has 8 of the total 70+ cans I installed. All of the trims are the same brand and model.
I won't be going to look at the issue until Monday evening.
I do know that the switch bank where the switch is located also has 2 Diva dimmers that are back lit devices.
The can lights in question are controlled with a single pole switch. The 2 back lit dimmers are controlling other lighting.
All lighting in that switchbox is fed from the same branch circuit.
The only thing that's different from any other switching with all the other cans is the presence of the 2 backlit dimmers.
Any help on what to look for would be appreciated.
