I agree with Ryan and would add that many habitable room do not even require a ceiling box.If in the nec where does it say all habitable rooms must have a ceiling fan rated ceiling box?
I agree, we always install them in kitchens, bedrooms etc. Having to go back and change just one when the HO decides that they want a fan (and it seems like they always do) makes up for the extra cost.While not NEC required, it is becoming an industry standard practice to wire with a fan rated box in any area or room that can physically accomodate a fan in the future
I'm quite surprised to learn that. You'd be hard pressed to go in any new construction in my area and find a room that doesn't have fan boxes installed. It's not just me. Every new resi EC in our local association is using fan boxes for new work, even in spec builds. A thread very similar to this one is just finished up on another board and most of the guys there responded that they were using fan boxes instead of regular ceiling boxes. Puzzled...Originally posted by pierre:
I don't know if this is an industry standard, as we do not see anyone here installing these boxes unless a fan is installed. There are more rooms than not that do not even have ceiling boxes, including bedrooms and family rooms, as these houses are being built as Spec homes.
Nope, just the rooms where it would ever possibly make sense to put a fan. I guess that's just the difference between a spec build and a custom. I don't intend to twist anyone's arm into installing fan boxes ahead of time. I just wanted to make the observation that I'm surprised that they're not on board with that already.Originally posted by allenwayne:
In that senario closet,stairwell and hall surface mounted lights are fan rated ???? Some ome needsto pound sand
mdshunk, A fan box is not even required where a fan is installed.Originally posted by mdshunk:
Bob I think I know where you are going with this so I`ll just come back later to see if I am correct in my thinking
True enough. If you put the long wood screws through the fan bracket, outboard of the box, and into some good wood above you could use a regular box. I'm not so sure that this is a method that very many use. I suppose that there are other methods to support a fan that doesn't totally rely on the box.Originally posted by iwire:
Neither of those sections require a listed fan box be used. A listed fan box is one of two options.Originally posted by redfish:
A fan box may not be required, however if you plan on installing a fan you must use a box that is listed or identified for support of paddle fans (2005 Code 314.27 & 422.18 )
Does the canopy on the fan cover the existig box? I have noticed that when you fasten the fan hanger to the structure that the box is fastened to, the canopy will not completly cover the box unless the canopy is unusually large.I have a large fan above me as I type this that is mounted over an existig box. The fan is screwed to the wooden structure.
