stickboy1375
- Litchfield, CT
alfiesauce said:We always GFCI protect anything over a shower other than a shower trimmed can.
I'm a rebel, I only protect whats required.
I hope I am reading this right. The intent of an exhaust fan is not for the steam produced by the shower, but the toilet bowl. That is why you must install a fan in a powder room with no window..steelersman said:Yeah I'm with you on that, but I have to say I've never seen an exhaust fan actually above the shower. They are always above the toilet even though that's not the true intent of them the duct man always puts them above th toilet.![]()
Nothing will remove the smell, exhust fans are for moisture only.g@friendly said:I hope I am reading this right. The intent of an exhaust fan is not for the steam produced by the shower, but the floater in the toilet bowl. That is why you must install a fan in a powder room with no window..![]()
Sorry you are wrong. If you go on the panasonic website it tells you how many cfms you would need to remove 1 drop of water. Also I believe that in the Boca code is where it says that it is for smell.stickboy1375 said:Nothing will remove the smell, exhust fans are for moisture only.
g@friendly said:Sorry you are wrong. If you go on the panasonic website it tells you how many cfms you would need to remove 1 drop of water. Also I believe that in the Boca code is where it says that it is for smell.
No moisture in the powder room.
A lot of the newer fans or coming out with humidity sensors now because, people have been for years installing them for moisture as "I have." these unit tend to post purge like a condesing furnace so that the steam clears the pipe and dosn't drip back into the room. Maybe an inspector can clear this one up for us.....
You are correct also nothing remove the smell quick enough. You just can't get the air exchange....
By the way I was told that they are going to be requiring straight pipe not flex for the bath fans... has anyone heard this?
g@friendly said:hey I agree.. I was shocked myself. but think about it the powder room?
here: http://www.hvi.org/assets/pdfs/HVI.BathroomFans_v3LOWRES.pdfg@friendly said:Sorry you are wrong. If you go on the panasonic website it tells you how many cfms you would need to remove 1 drop of water. Also I believe that in the Boca code is where it says that it is for smell.
g@friendly said:That is why you must install a fan in a powder room with no window..
The camp smiley stank code of 1968iwire said:I have never seen a requirement to install a fan in a powder room with no window, can you point out what code and what section requires this?
peter d said:I plumbed a brand new house a few years back...start to finish. That turned out....ummmm....interesting?![]()
g@friendly said:No moisture in the powder room.
g@friendly said:A lot of the newer fans or coming out with humidity sensors now because, people have been for years installing them for moisture as "I have."
