M mstrlucky74 Senior Member Location NJ Jun 11, 2017 #1 Just curious, would a j-box be need here even though they shown it? or would you just wire to the motor rated toggle and whip to the unit? Thanks. Attachments Capture.jpg 15.2 KB · Views: 0
C cdslotz Senior Member Jun 11, 2017 #2 I would put in a J-box and install the switch in it. A J-box would be needed to continue the circuit to other fans on that circuit
M mstrlucky74 Senior Member Location NJ Jun 11, 2017 #3 cdslotz said: I would put in a J-box and install the switch in it. A J-box would be needed to continue the circuit to other fans on that circuit Click to expand... Those thermal F type switches come with a box.
infinity Moderator Staff member Location New Jersey Occupation Journeyman Electrician (retired) Jun 16, 2017 #4 For us many times the mechanical contractor proves the correct thermal switch/box (just like they supply VFD's and motor starters) along with the proper heaters. It may even come installed on the equipment.
