1793
- Louisville, Kentucky
- Inspector
celtic said:Did you see this?
http://www.dryspace.cc/pdf/CeilingFanInstallationTips.pdf
It got me thinking....put ANY weatherproof box you want in, and lag bolt the fan's back plate to the beam ....yes/no/maybe?
If you can seal the hole around the wiring, why not the joist pan?
brantmacga said:i use the red-dot boxes.
celtic said:Norb,
maybe it might be best to simply ask the manufac. what box they use?...
celtic said:Are they fan rated[422.18 et al]?
I can't tell over here:
http://www-public.tnb.com/ps/fulltilt/index.cgi?part=LVX1
http://www-public.tnb.com/ps/fulltilt/index.cgi?part=LVX2
Pierre C Belarge said:I do not believe that either of those two boxes are fan rated. I am pretty sure it would be stated as so with the documentation.
That's just funny...LOL.Pierre C Belarge said:If fans are installed, and they do not fall immediately, that is just good fortune.
I think we've all seen that.Pierre C Belarge said:What happens in a season or two or three when the torque of the fan running finally causes the fan to give way from the box? I am not an engineer, but I have seen the threaded portion of those boxes fail before, without fans installed.
