In the master bedroom of this new house I have a 2g switch box the first switch is a standard single pole which operates 4 6inch recessed cans with led lts, the second switch is a leviton fan speed control (no light kit or nuetral) the are on the same master lighting circuit additionally there is the same can setup in the master bathroom which is a seperate box but same circuit. When I have all the cans (including the one in the bathroom) on and turn on the fan speed control the cans will blink once, from setting to setting. I've replaced the controller which helped a little but its still not perfect. So I put in a single pole switch in place of the controller which does not make the cans blink but it's just a temporary fix. Does anyone know why I'm having this problem and how to fix it? Any help would be appreciated, thank you
