winnie
- Springfield, MA, USA
- Electric motor research
I'd like to propose an addition to the FAQ.
<B> When does a neutral count as a current carrying conductors for purposes of 310.15(B)(4)?</B>
Code requires that the ampacity of conductors be adjusted if several conductors are bundled together, for example in a single raceway. The reason is _heat_. The rules of 310.15(B)(2) are there to prevent excessive temperatures caused by the heat production of several conductors bundled together.
In general, <B> all </B> of the conductors in a circuit will carry some current, and this includes the neutral conductor. Thus, in general <B> all </B> conductors count when applying 310.15(B)(2).
There are a few specific circumstances where the neutral doesn't 'count' for 310.15(B)(2); these circumstances are outlined in 310.15(B)(4).
These rule can be better understood if the focus upon the neutral is ignored. Rather than asking 'does the neutral carry current', ask 'Given this set of 3 (or 4) conductors, how much heat is produced?'
In general, the neutral will carry some current, even when 310.15(B)(4) tells us that we don't have to count it.
There are _two_ specific situations where this applies.
1) The neutral conductor of a 3 wire circuit derived from a _single_ phase system. In this case, even though there are _three_ conductors which potentially carry current, the _net_ heat produced by these three conductors is always less than or equal to that of _two_ fully loaded conductors.
2) The neutral conductor of a 4 wire circuit derived from a three phase wye connected system where there the major portion of the load is linear. In this case, even though there are _four_ conductors which potentially carry current, the _net_ heat produced by these four conductors is always less than or equal to that of _three_ fully loaded conductors.
In the following cases, the neutral must count for 310.15(B)(2)
a) Single phase circuits with _dedicated_ neutrals. In this case, there are _two_ conductors which potentially carry current, and the net heat produced will be that of two conductors.
b) three wire circuits consisting of two phase conductors and a neutral, derived from a three phase wye connected system. In this case, there are _three_ conductors which potentially carry current, and the net heat produced will be as much as that of _three_ fully loaded conductors.
c) four wire circuits consisting of three phase conductors and a neutral, where the major portion of the load is non-linear. In this case, there are _four_ conductors which potentially carry current, and the net heat produced can exceed that of _three_ fully loaded conductors.
Basically the implications of 310.15(B)(4) are that we only have to count a total number of current carrying conductors equal to the worst case heating expected for a given circuit.
-Jon
-Jon
