This is an instruction on how to ground a couple of single phase transformer.
Could someone explain what it is referring to? It seems like "fargo" is being used as a verb and "Asbury loop" is a particular way to do the grounding.
The issue is being asked also in http://www.eng-tips.com/viewthread.cfm?qid=252527&page=10 and the only reference is a 1986/87 blueprint from the DOA.
The full note reads: "GROUND WIRE AND TWO GROUND RODS TO BE INSTALLED AT LEAST 24 INCHES BELOW FINAL GRADE. LOOP GROUND WIRE INTO EACH VAULT AND FARGO TO ASBURY LOOP"
The print can be seen at http://www.fs.fed.us/database/acad/elec/ed000107.pdf
Thank you for your help
