todd.toddy@hotmail.com
- Boulder, CO
Hello everyone,
I have a quick question about fault calculations. Specifically, how I can model an induction motor in a positive sequence reactance circuit, negative sequence reactance circuit and zero sequence reactance circuit in order to perform a 3-phase bolted fault current, single-line-to-ground fault and line-line fault.
The only information that was given to me about the induction motors was its subtransient reactance and its transient reactance.
Can I just assume that the subtransient reactance is a good value to use for its positive sequence reactance? Or can I assume that the transient reactance is a good value to use for its negative sequence reactance? What about the zero sequence reactance?
Thank you.
Thank you.
