GilbeSpark said:
I have Sprint service and don't have nearly the problems I do with Nextel. I think they run on different networks which have different frequencies.
Gilberspark, I owe you an apology, there is still some difference between NEXTEL and SPRINT. For lack of a better word NEXTEL is a queer with their technology, they use iDEN modulation. They developed it for their PTT function. However it is being phased out now and completely in the near future. The technology and frequencies is reportably being sold to the US military for their own use.
I found my mistake this morning when I went back to work; I work for a cell phone carrier so I have access to a lot of inside info. So is you are in an area that still uses NEXTEL iDEN technology is more than likely the reason for all the problems.
For all of you trying to figure out which is best I can sum up pretty quickly. You want to find a carrier that uses CDMA technology in the Cellular band of 800 MHz, rather than GSM or TDMA (TDMA is history December 2008 as the equipment manufactures will no longer support it).
CDMA has many advantages over GSM and TDMA; most importantly data speeds, security, and 4 times the capacity for a given bandwidth.
The list is rather short and you can easily tell which carriers use what. The catch is which band Cellular (800 MHz) or PCS (1900 MHz)
CDMA carriers are:
Verizon (Both Cellular and PCS, depends on market area)
Alltel (Cellular band only)
US Cellular (Cellular Band only very limited coverage and services like data)
Sprint (PCS band only)
Verizon is the largest and best out there with all the bells and whistles. Here is a word or two of advice. Sprint and US Cellular are in deep trouble and will likely be bought out by the other two (Verizon or Alltel). Alltel just went private and it is not known what exactly will be done with it. Rumor has it one of two things.
- Alltel will buy US Cellular, merge the two, slash employees and cost, then sell out to Verizon.
- Or just slash cost and employees, then sell to Verizon.
- As for SPRINT, Verizon is just waiting for the right price which shouldn?t be long as SPRINT is undergoing layoffs and cost cutting right now to stop their market cap slide to $0.
Short story is Verizon will be the CDMA carrier in the end.
On the GSM/TDMA side you have:
ATT/Cingular
T-Mobile
Quest
