Re: Federal Pacific Panels
Federal Pacific bolt-in circuit breakers are just as bad.
One experience that I have had with Stab-Locks is that turning off the circuit breaker and turning it back on when changing a broken receptacle will restore normal overload protection. Then, the customer finds out that they have 30 amps of load on a 20 amp circuit. Go back and pull a second circuit through the conduit.
Evidentally, many FP circuit breakers worked when new but developed arthritis after a few years and this was one of the things that contributed to "aluminum" wiring failures. Actually, before the invention of silicon lubricants ALL circuit breakers tended to develop arthritis unless exercised at least once per year.
Believe it or not even SquareD recommends to this day that their circuit breakers be cycled off and back on once or twice a year to prevent arthritis.
One reason for the popularity ( at one time ) of oil circuit breakers on utility transmission and distribution systems was that they had less tendency to jam. However, improvements in sulfur hexafluoride and vacuum circuit breakers had reduced that advantage to almost nothing.
