Just got a call from one of my customers.
He has an old dry cleaning plant that has two 100 amp. 3 phase 120/208 service both meters are inside. He had his power cut off and now he wants to rent the Bldg. out and the power utility co. want turn it back on since the meters are on the inside of the Bldg.He loss the grandfathering law when he had it cut off and now it is outdated.Now they require the meters to be outside.
He wants me to install a single phase 200 amp. 120/240 volt service since the person renting it will not have any equipment.A simple through the wall service with the meter outside.
My question is, can I legally set 2, 3 pole 100 amp. breakers in the new 200 amp. single phase service panel and feed the exsisting 2, 100 amp. panels and making them sub panels? Or set 2, 2 pole breakers as feeds and tie two of the legs together in the 100 amp. sub. panels?
Ronald
Ronald
