Question about a possible setup here
Customer has a 200 amp feed thru panel which is currently full except for the feed thru lugs. They want to add a 100 amp sub panel in the garage of the building. They want to avoid using tandem breakers to free up space for a 2-pole 100 amp breaker so here is my theoretical solution.
I want to come out of the feed thru lugs of the 200 amp panel with #2 aluminum conductors, and hit a 100 amp breaker in the sub panel to feed that panel. Is there anything preventing this? In my mind the conductors would be protected by the 100 amp breaker in the sub panel.
Any suggestions or answers are appreciated.
Thank you in advance
