feeder cable ques?
wireman1
can you run feeder cable fed from a six gang meter base with 100 amp breakers to sub panels located in the basement with out protection for the sers cables this bldg. is a apt. bldg. six gang is a meter stack
what do you mean "without protection"? Sounds like they are protected by a 100 amp breaker, or are you talking physical protection? Running SE cable exposed in/on a building is fine 99.5% of the time.
If you are saying no main breaker in sub panel, sounds like you have your service disconnects already...MLO would be fine.
