I would like to know if is permitted by NEC to install feeder cables (let say a run of four single conductors THHN) from a MDP (main distribution panel) through the walls of a commercial building to a main disconnect switch on an equipment. The installation of the conductors are without any type of conduit (metallic or non-metallic) just the cables directly in contact with the wall concret or blocks.
Thank you
			Thank you
