new user. The local fairground has a 400A single phase ct cabinet with double lugs on the load side. Under each lug is a pair of 4/0 al feeding two 200 amp panels adjacent to the ct cab. Each panel then has 3 200A breakers feeding overhead to 3 subpanels for 120v convenice outlets mounted on poles. At the top of the first pole after the mdp the 4/0 is then crimped on to what looks like #2awg. Two questions i have are why the smaller overhead wire and why only 4/0 from the 400A ct to the 200A panel.
