Feeder for shore power
nickelec
US
I'm trying to calculate the size of a wire I would need for a feeder. I need to run about 2500 ft at 277 480 volts to a step down 120 208 transformer and get 200 amps on the secondary
I'm having a brain fart on how to calculate the size of the primaries
Sent from my SM-S906U using Tapatalk
Does it pay to use the step up transformer and then another step down at the end
Could that even be done 480 stepped up to MV. I've never done that before..
Just trying to help a customer out with some viable options
Not uncommon and for half a mile, might well be worth it, but you have to do the pricing exercise to know. Also depends on whether you can/are allowed to run MV around, could be a local restriction or no good place to put the cables.
Is this going in pipe or overhead? Much easier to do MV if it's overhead.
"Shore Power" = Marina or Dock
55.4 in the '17 prohibits over 1000 volt
