NECA labor manual lists various device and wiring labor time. They make up time by ft., each device or per hundred or thousands. The you just multiply by you labor rate. Use of manual is tricky if you forget even one component of installation you can end up shorting your bid, as you need to account for every component.Labor rates ($/Hr) are based on number of factors by region.
I’ve never heard of having a specific rate based on the pipe and wire size being run???!
unless you use assembliesNECA labor manual lists various device and wiring labor time. They make up time by ft., each device or per hundred or thousands. The you just multiply by you labor rate. Use of manual is tricky if you forget even one component of installation you can end up shorting your bid, as you need to account for every component.
