Okay, to start with, I am fresh out of school, just a junior employee at an Engineering firm. I'm working on a project that the owner wants to add a standby generator to an existing building that has two separate main switchboards (2000A ea.) both fed from the same utility transformer, however metered separately. I have been told that we will do this adding a new MSB that is dual fed from the utility transformer. It will contain (2) 2000A MCB each followed by an ATS which are also fed by the generator. This feeder is the one in question. I am currently showing this is a 4000A feeder from the generator to two 2000A breakers which then feed the ATS's. Ultimately, I want to know how to size this large feeder. Of course I have plenty of supervision, but seeing as how I have just recently started working here, I wanted get some incite on this topic before presenting it to my superior. Other information you may need in helping: 120/208V, 4000A, 3P, 4W, THHN wire...
Thanks for any help you may be able to give me on this project.
