Feeder to subpanel
Ricknj59
New User
NJ
I am installing a 100 amp subpanel in a pole barn 200 ft away from the service panel to the house. I am planning to run 3 # 1 AL conductors 2 hot and 1 neutral along with a #6 copper ground wire. Can I downsize the neutral ? Does the #6 ground wire need to be insulated ? It will be in PVC conduit only exiting the house and entering the barn. I am planning to install one ground rod at the barn-do I install the green screw from the neutral bar to the back of the panel in the subpanel ?
Thank You
This seems like a diy type question and we are not allowed to help diyers. Best bet is to hire a licensed electrician to do this work for you.
This site is designed for:
  • Electrical Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
This NEC® Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Knowledge and the practical application of the National Electrical Code is an essential part of all electrical installations. If it's important for you to understand the National Electrical Code, then look no further.
To better help us serve you, please be sure to update your account details with your occupation field and location if you have not done so already. You can access your account details by clicking on your account name at the top right of the page when on the forums.
