big john
- Portland, ME
Here's the layout:
There was an existing surface-mount panel with everything piped into it. More space was needed so a second surface-mount panel was set right next to the first, and chase nipples were run between the two enclosures. The original panel has a main breaker; the added panel is MLO and is fed from the original.
Instead of piping to the new panel, the installers just used the existing pipes and ran new circuits across the existing panel, using it as a raceway.
The feeders and branch circuits for the MLO panel are also both running through the same chase nipple.
Everyone is up in arms about this installation:
"You can't use a panel as a raceway!"
"You can't run branch circuits and feeders together!"
It looks like 312.8 says you can use a panel as a raceway, but I can't find anything about running feeders and branch circuits together, I just have a bunch of guys swearing that it's "code".
Any ideas? Thanks.
-John
Any ideas? Thanks.
-John
