dburney
- Brooklet ga usa
I have a job where we have to install new booths under a canopy 14 of the to be exact the booths will have a 125 amp mlo panel in them and we will have a non fused disconnect on the outside of the booth. The booths will be fed from a panel inside the main building off a 50 amp 2 pole breaker the longest running would be about 300 feet. They will be fed with 2 hots a neutral and a ground. My question is can I run the feeds for 2 booths in the same conduit and if I can would a de rating factor come in to play
