stevebea Senior Member Location Southeastern PA Apr 14, 2011 #1 I'm looking for something that I'm not sure exists. 20 Amp 125 Volt Right Angle Female Cord Cap. Non Twist Lock. Thanks!
eric9822 Senior Member Location Camarillo, CA Occupation Electrical and Instrumentation Tech Apr 14, 2011 #2 Like this? http://www.fruitridgetools.com/stor....aspx?sfid=136763&i=16211607&mpid=8171&dfid=1
stevebea Senior Member Location Southeastern PA Apr 14, 2011 #3 eric9822 said: Like this? http://www.fruitridgetools.com/stor....aspx?sfid=136763&i=16211607&mpid=8171&dfid=1 Click to expand... Thanks Eric!
eric9822 Senior Member Location Camarillo, CA Occupation Electrical and Instrumentation Tech Apr 15, 2011 #4 stevebea said: Thanks Eric! Click to expand... You are welcome.
stevebea Senior Member Location Southeastern PA May 7, 2011 #5 eric9822 said: Like this? http://www.fruitridgetools.com/stor....aspx?sfid=136763&i=16211607&mpid=8171&dfid=1 Click to expand... This link Eric shows an angle plug, but if you look up the Leviton part number it is a straight blade connector body.After some searching I found P&S makes an angle adapter to use with connector bodies.
