If you are installing any type of wiring method in an environmental air space (Plenum) then there is a restriction on the type of wiring method. If the area above the suspended ceiling is not used for return air then there are no restrictions
Note in a plenum space even if you use plenum rated Smurf tube you are still required to use plenum rated fiber optic cable
