ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
Usually it's a switch to either lift the ground or not.The DI should take care of that, at least the good ones do.
Likewise, there are wireless solutions:I think most of the fiber optic HDMI cables are a hybrid type where there are still copper wires for control purposes which include a ground return, and so they may not provide the isolation you need. "HDMI extender over fiber" modules are connected only by fiber and therefore should provide good isolation.
And the DI needs to have ground lifting capability. Some do not.If putting the DI between the laptop and mixer (while the HDMI is connected) produced the same noise, I'd immediately suspect that DI; which one are you using? (I'm a fan of the Whirlwind products, and their IMP2 box; the Samson ones are supposed to be pretty good, too.)
Use something like this to isolate that stage input from your house mixer, install it such that it won't get bypassed or removed.
PI-2XX | Jensen Transformers
The design begins with a rugged flanged enclosure that comes standard with gold plated XLRs and a removable screw-down barrier strip for easy installation in NEMA enclosures. Plug and play easy to use, this passive interface does not require any power to work. Inside are two Jensen high...www.jensen-transformers.com
Then have something like this for when your stage input is something other than a balanced line level source
ProAV2 - Radial Engineering
The ProAV2 is a 2-channel passive direct box designed specifically with AV integrators in mind, with multiple input connectors to easy interface with any audio source device.www.radialeng.com
I'm pretty sure with the audio isolation between a DJ's mixer and the house system, it wouldn't matter that the DJs laptop is plugged directly into his mixer since the mixer is isolated from the house system.
Thank you for your input.I'll add that if you isolate the HDMI and not the audio, you are still susceptible to noise if the DJ mixer has a grounded power cord or another path to ground.
The noise was gone when I put the box between the laptop and the house mixer, The noise is present when I put the box between the mixer and IT rack.If putting the DI between the laptop and mixer (while the HDMI is connected) produced the same noise, I'd immediately suspect that DI; which one are you using? (I'm a fan of the Whirlwind products, and their IMP2 box; the Samson ones are supposed to be pretty good, too.)
The mixer DJs or Bands bring gets plugged into the house mixer right? The two pieces I listed above will take care of pretty much every scenario of outsiders plugging their gear into the house PA.2- The DI box between the laptop and the house mixer - eliminated the noise. (As mentioned future djs or bands will bring thier own mixer so this is not a permanent solution).
That's the correct place for it.2- The DI box between the laptop and the house mixer - eliminated the noise.
So you plug their mixer into the DI. The point is- get some isolation in there!(As mentioned future djs or bands will bring thier own mixer so this is not a permanent solution).
You have some good suggestions and yes the entertainment will plug into the house mixer which is at the stage. Say we isolate the house mixer output from the pa and then we isolate the performer's input between their equipment to the house mixer. I would ask if it would still be possible for ground noise to be generated on their end between their laptop, their mixer, their monitors, etc when pluggin into our hdmi and then the noise be broadcast to our system outside of the isolation.The mixer DJs or Bands bring gets plugged into the house mixer right? The two pieces I listed above will take care of pretty much every scenario of outsiders plugging their gear into the house PA.
ok I understand your suggestionI don't think you need to isolate between the house mixer and the PA, just between the 3rd party gear and the house mixer.
ok I understand your suggestion now
again if I Isolate as you suggested would it still be possible
for ground noise to be generated on the band /dj end between their laptop, their mixer, their monitors, etc when plugging into our hdmi on their side of the isolation and then the noise be broadcast via audio to our system anyway?
