Hugh judge
I was recently sent on a residential service call involving swimmers recieving (intermitently) a small 'tickle" from the hand rail when exiting the pool. I was unable to register any voltage between the rail and any of the related surfaces (water, screen room, etc.) nor did I find any device issues or installation mistakes. I observed this however: the nature of my question, there is no path to ground of any kind for the water. the pool is plastic as is the pipe, all the fittings the pump, the roof-top solar heater, etc. in the event of an electrical discharge being introduced to the water at any location it would have no alternative but to use the unlucky swimmer holding the well grounded hand rail. have I missed something or is there no currently required means of grounding the water? perhaps a brass fitting somewere in the water piping attached to our #8 bond?
