- Lockport, IL
- Semi-Retired Electrical Engineer
It is common for specifications to require that when an underground ductbank turns up towards the electrical room, the 90 degree sweep is to be done with rigid steel conduit, even if the rest of the conduit is PVC. First question: why? I am told that it is because the process of pulling cables can cause damage to PVC at that final bend, and that the rigid steel is used to provide higher strength. Second question: does that make sense?
Now the real issue. An EC elected to use some type of reinforced fiberglass material, instead of rigid steel, for the 90 degree sweep. We (the designers of record) are being asked to approve the substitution (after the fact, of course). Third question: has anyone seen this before, and if so is it better or worse than the rigid steel?
