Field modifications
goldstar
New Jersey
Electrical Contractor
It's hard to put this into words so I thought a picture would do the trick. A homeowner gutted his 2nd floor bathroom and pulled up the floor before we came in, only to find these remodeled, remodel type hi-hats. :
Remodeled hi-hat-1
The plumber was also creative in this one and bent a saddle in his water line. Is necessity really the mother of invention :rolleyes:
Remodeled hi-hat-2
celtic
NJ
OMG.
At least they knew enough to protect the cold water line from heating up :grin:
iwire
Massachusetts
Don't act Innocent, you recognized that immediately. :D
I thought the cut was done very cleanly, of course the correct way would have been to go up stairs and notch out both joists from the holes up and just bend the copper up. :wink:
goldstar
New Jersey
wbalsam1 said:
Was this done by the plumber or the electrician, or do you know?
Don't know, but would it make a difference ? If you were setting in a toilet would you cut away part of the packing donut to get it to fit :confused::grin:
bphgravity said:
Isn't it odd that electric, plumbing, and mechanical equipment always seem to end up needing to occupy the same place...
I guess it's a question of who gets there first. Probably wouldn't have had a problem if the plumber came in 2nd and used PEX.
peter d said:
Those cans are no longer air tight.
This is the new version to meet the energy code. It allows the hot air to escape and heat the rest of the ceiling. Kind of like having a ridge vent cut into your roof. It creates a natural convection.:grin:
goldstar
New Jersey
minuteman said:
That's a clean cut. It may be hack work, but it was not hacked up! Somebody took a lot of good time to something the wrong way.
You're right. I can say with certainty that had I chose to do something like that the cut wouldn't look anything like the perfect cut that was made. Probably used a side grinder or Fein Multi-tool. Either way, a lot of thought went into making the cut, as you said.
r_merc
North Carolina
Saddle
Saddle
I'm Impressed with the plumbers Saddle. Must of been a plumbtrician I didn't think that such a thing was in a plumbers bag of tricks.
Rick
220/221
AZ
It was clearly done by the person who installed the remodel can. I wouldn't refer to him as an electrician though.
I admit, I have banged the top of a can or two to squeeze it in to an unexpected obstacle, but that is a little much. I have even popped the rivets off the top,trimmed the can down with tin snips and screwed the top back on.:cool:
BTW, he should have seen the pipe when he pulled out the original JB and just relocated it a bit.
