- Placerville, CA, USA
- Retired PV System Designer
Actually there is no limit as long as you have enough dominoes and time.1 micron or so less than the length of a domino
Hovevere, if you stack lots..
The theoretical limit comes when 1/N, where N is the number of dominoes, is no longer a workable distance.
By then you may have extended hundreds of domino lengths.
The extent can be approximated by ln(n+1) where n is the number of dominoes you have stacked.
