SpaceTentacle
- Martinez, Ca
I am installing a new 30kva 480-120/240 transformer on a wooden pier. I cant drive a rod, there is no building steel. Im installing next to a 480v panel which will feed the primary. The 480v panel seems to have a good ground and is fed from switchgear several hundred feet away. Is there any reason i shouldnt use the EGC in the 480v panel feeder conduit as my electrode for my new transformer, making sure the wire is bonded correctly to the electrode at the switchgear? Then, let the conduit serve as the EGC.
