hurk27
- Portage, Indiana NEC: 2008
Re: Finding the location in the attic
Kenneth
I keep a file to sharpen the bit every so often as they do dull quick and I agree that with my 18 volt De-Walt hammer drill If I don't use the clutch They will snap or break loose from the bit/shaft connection. But Loews has replaced every one that I have brought back with out a question. Menard's well that's a different story. But like anything else if you run into obstacles you have to find away around it. and with these bits I try to not push them too hard I just let them do the work when the wood is hard.
Kenneth
